Upon my recent thread here
https://forum.videohelp.com/topic348913.html
NOTE: AFTER APPLYING THIS FIRMWARE, YOU WILL LOSE HDMI CONNECTIVITY. This is because the USB 23 Character filename is from the 5960 ARM core, which doesn't have a HDMI port. I repeat, you will lose HDMI connectivity and I haven't tested if you could revert the flash.
Expert firmware modder, Tech25, patched the 5982 firmware to have 23 Characters in the USB Browser and GOTO function for USB. I was the guinea pig for you all, so I hope you enjoy it. In a sum, this is what he added.
1. 23 Characters in USB Browser (The max limit of characters this player can support in USB mode is 23)
2. GOTO function by pressing TITLE button twice.
If you don't use HDMI then this firmware is for you. Component works perfect.
DOWNLOAD
www.portabellos.ca/download/DVP5982_37_ryan0.3b_tech25patch.zip
[Release] Philips 5990/12 modded firmware by vb6
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 140Last Post: 28th Sep 2015, 03:06 -
[Release] Philips 5982 Modded Firmware v0.4
By shadow_cruiser in forum DVD & Blu-ray PlayersReplies: 34Last Post: 29th Jun 2009, 19:51 -
philips 5982 divx usb problems
By fredwilson in forum Newbie / General discussionsReplies: 7Last Post: 15th Feb 2008, 23:42 -
Philips 5982 and USB
By chits007 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Dec 2007, 09:43 -
Philips 5982 firmware to support more then 8 characters
By elec999 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Sep 2007, 12:27
